- This topic has 12 replies, 4 voices, and was last updated 6 years, 1 month ago by
Yuri Kovelenov.
2020-07-12 at 7:35 am #29985
GLiFTeKCustomerHi,
Can you use the “create canvas” puzzle to have interactive html5 canvas pages mapped onto our 3d object geometry faces?Thanks
plz share Discord link & on your signature!2020-07-13 at 4:42 pm #30058
Alexander KovelenovStaff2020-07-21 at 4:15 pm #30423
robinson007Participant“create canvas. I don’t know how to create it, I can’t find it in Puzzles.
2020-07-21 at 4:47 pm #30427
Yuri KovelenovStaff“create canvas. I don’t know how to create it, I can’t find it in Puzzles.
it is included in the 3.3 preview build
2020-07-22 at 2:51 am #30438
GLiFTeKCustomer“create canvas. I don’t know how to create it, I can’t find it in Puzzles.
Hi Robinson,
It’s in the HTML Puzzles group.Visit the GLIFTEK Verge3D Plugins Store!
plz share Discord link & on your signature!2020-07-22 at 2:53 am #30439
GLiFTeKCustomerHi, Why not, you can draw anything to that canvas!
Can you include an example project app with the canvas puzzle working please?
I have copied the example js in the manual and have no successful results.
Thanks!
plz share Discord link & on your signature!2020-07-24 at 10:08 am #30599
GLiFTeKCustomeri have it working.
i’ts on the corner.
plz share Discord link & on your signature!2020-07-24 at 1:08 pm #30606
GLiFTeKCustomerwhat’s the correct method of implementing canvg.js, path2d, or fabric.js to just.. simply.. have an SVG file read, and put to the canvas?
tried all three and got them working on their own.. just not with verge.even the simplest method wont work.
i’m trying:
var canvasTex = v3d.puzzles.canvasTextures['my_canvas']; var canvas = canvasTex.image; var ctx = canvas.getContext("2d"); var SVGimage = document.getElementById("svg"); ctx.drawImage(SVGimage, 0, 0); canvasTex.needsUpdate = true;where my HTML has:
<object data="./mySVGimage.svg" type="image/svg+xml" id="SVGimage" ></object>i have my myapp.js called AFTER that line so it’s defined.. but still isn’t… if it’s not that problem, it’s another.
this should be more simple than how I’m construing it i think…
plz share Discord link & on your signature!2020-07-24 at 10:40 pm #30617
GLiFTeKCustomertrying this… witch SHOULD work..
var svgElement = document.getElementById('SVGimage'); let image = new Image(); image.src = svgElement; var canvasTex = v3d.puzzles.canvasTextures['my_canvas']; var canvas = canvasTex.image; var ctx = canvas.getContext("2d"); var width = canvas.width; var height = canvas.height; ctx.drawImage(image, 0, 0, width, height ); canvasTex.needsUpdate = true;but i get this new error…with the usual lazy initiation … new one being KHR…
v3d.WebGLRenderer: KHR_parallel_shader_compile extension not supported. v3d.js:1:563760 WebGL warning: generateMipmap: Tex image TEXTURE_2D level 0 is incurring lazy initialization.
plz share Discord link & on your signature!2020-08-14 at 3:21 am #31526
GLiFTeKCustomerany . ideas?
plz share Discord link & on your signature!2020-08-14 at 8:05 am #31539
Yuri KovelenovStaffKHR_parallel_shader_compile extension is a warning that should not affect the app.
image.src = svgElement;I’m not sure if you can assign an HTML element simply as src of an image.
You might look here for possible methods of drawing SVG on canvas:
https://blog.idrsolutions.com/2012/09/how-to-draw-svg-on-html-5-canvas-and-why-you-might-want-to/2020-08-15 at 2:59 am #31564
GLiFTeKCustomerKHR_parallel_shader_compile extension is a warning that should not affect the app.
I’m not sure if you can assign an HTML element simply as src of an image. You might look here for possible methods of drawing SVG on canvas:<iframe class=”wp-embedded-content” sandbox=”allow-scripts” security=”restricted” title=”“How to draw SVG on HTML 5 Canvas and why you might want to” — Java PDF Blog” src=”https://blog.idrsolutions.com/2012/09/how-to-draw-svg-on-html-5-canvas-and-why-you-might-want-to/embed/#?secret=krBmpdegZz” data-secret=”krBmpdegZz” width=”600″ height=”421″ frameborder=”0″ marginwidth=”0″ marginheight=”0″ scrolling=”no”></iframe>
Getting svg to canvas is no problem.
I’m focused on getting ANY image format drawn on the canvas produced with the puzzle.
Let’s talk on it at this discussion…
Going on three weeks of attempted functionality here…
Thanks!
plz share Discord link & on your signature!2020-08-15 at 10:55 am #31578
Yuri KovelenovStaff -
