Can illumination effect work in V3D
Home Forums General Questions Can illumination effect work in V3D
  • #31587
    visualizer
    Hey
    Is it possible to have illumination effect in verge 3d?
    also if I use illumination from blender baked textures/materials will it remain in verge 3d?
    Any ref link for puzzle setup or example.
    Cheers
    #31590
    can you elaborate a bit so that I can provide you with a precise answer?
    #31593
    visualizer
    Ahh sure !
    I mean this type of backlit effect. Either name or keyboard etc.
    I was looking for this type of effect.
    Also in addition to this is this effect possible in V3D directly or it needs to be brought into V3D by texture baking in blender?
    In that case does V3D support illumination texture?
    See attached images
    Hope its clear what I m trying to say.
    Cheers
    #31603
    such an effect can be done using an emission shader combined with bloom (also need to enable HDR rendering).
    #31621
    visualizer
    really?
    doable in V3d?
    #31633
    yep, you can give it a try
    #31858
    visualizer
    I was trying to play but still think illumination & GI are two different issues.
    Emission with bloom may satisfy some needs however the vibrancy is not being achieved as expected I believe.
    Specially when I need two images side by side one normal and another backlit feel.
    #32163
    visualizer
    Hey
    any words pl?
    #32180
    you could probably emulate lighting with another shader applied to the background. Or you can bake the lighting rendered with a non-realtime renderer.
    #32222
    GLiFTeK
    You could make a baked AO map in your 3d package or use verge3d’s post processing effect… an AO, (ambient occlusion) hack where the shadow is the glow, making the shadow color light blue. Bump up the settings high, then use a different texture (yet identical without AO map (won’t work in Verge post effect, only map) so the tops of the keys won’t have the glow.
    3d/CG is 80% hacks, workarounds till it works. ;-)
