Home Forums Graphics / 3ds Max Camera Target animation
Viewing 11 posts - 16 through 26 (of 26 total)
  • #13489
    then you can probably parent the camera to the object and it will follow it
    #13498
    daveli
    Yes, I did this, the camera constrained on the object and followed the object motion, and used a free camera, all in the 3dmax software, there is no problem, but in the verge3d program the camera still keeps looking at the coordinate origin. I don’t know if there is a problem in 3dmax, or if verge3d is not perfect.
    #13500
    can you attach an example Max file here (must be less than 4 Mb), so that we can take a look at this?
    #13504
    daveli
    Of course, the max file version number is 2018, but the texture texture is not included in the file. In addition, please check the physical material import verge3d can not identify the texture texture, I think the texture problem should be an example. thank you very much.
    #13506
    daveli
    I uploaded the zip file, but I didn’t see if the upload was successful. Have you received the file?
    #13508
    Nope, seems it’s not attached. You can also try uploading it somewhere else and posting here the link
    #13509
    daveli
    https://drive.google.com/file/d/1uFdr_p33N4AXmdwt4h6cY034h6pGO5nq/view?usp=sharing
    This is a shared link to Google Drive. After you get the file, I will delete the link.
    #13534
    thanks for the file, we’ll take a look
    #20472
    we did a lot of camera and constraint improvements lately. Is this issue still present in the recent version of Verge3D for 3ds Max? :scratch:
    X | FB | LinkedIn
    #20481
    daveli
    Hey, thank you for your attention and persistence. After updating the new version of Verge3D recently, the problem with camera target animation has become much simpler, which has solved the problems I have encountered before. thank you very much.
    #20485
    :good:
