Camera Puzzles Tutorial – Empty Follows Mouse Object
Home › Forums › Graphics / Blender › Camera Puzzles Tutorial – Empty Follows Mouse Object
Viewing 14 posts - 1 through 14 (of 14 total)
  • #49605
    ma77hew
    I am following the tutorial shared here on Verge3D Camera/Lights page:
    https://www.soft8soft.com/docs/manual/en/puzzles/Camera.html
    In the following example, an object looks at the mouse cursor. This can be achived by mapping the position of an empty/dummy object to mouse cursor with some simple math.
    Verge3D Puzzle Setup
    In order to setup such behavior in 3ds Max, make your object follow a dummy object by utilizing the Rotation Controllers / LookAt Constraint. In Blender, this corresponds to the TrackTo constraint.
    I have followed these instructions and the result works as expected but the animations extremely fast. How can I slow down this camera movement? Or make it less sensitive?
    – I’ve tried playing with the values
    – I’ve tried unticking “inverted” for the mouse option. This seems to slow it down.
    #49722
    ma77hew
    Any advice on this?
    #49725
    ma77hew
    I can’t seem to get this to behave in a consistent fashion. Now, it seems the orbit moves much more slowly. Here is my setup on Puzzles and my camera setup on Blender.
    I am following your tutorial directions.
    Please help me figure this out.
    #66548
    Hey I know it is super late but I had similar problem and that’s how I solved it:
    https://v3d.net/nf1
    https://www.youtube.com/@Contret
    https://x.com/_Contret
    https://www.behance.net/Contret
    https://www.artstation.com/contret
    https://vimeo.com/user175083946
    #66553
    Every frame? :scratch: It’s enough to use “on mousemove”…
    https://v3d.net/bdd
    #66562
    Tried it, works well, thanks! Haven’t thought of it yet :-)
    https://v3d.net/nf1
    #68821
    ma77hew
    Never got this to work for me, even after following these instructions. Can you provide you show me your project and puzzle?
    #68854
    ma77hew
    Does anyone have a working example of this? it’s on the Verge3D official documentation and yet I still have not seen it working ever
    #68878
    https://v3d.net/qna
    #68894
    ma77hew
    Thank you for your help @kdv. Other users should know additionally to check this option to achieve the interaction as stated.
    You are using Orbit as a camera control? How can we use First Person?
    #68895
    The same way. But it’s next to senseless. And you can’t use it if the pointer is locked.
    #68896
    ma77hew
    I actually switched to try but it seems this disables the AWSD keys. I am looking into solving this right now
    #68918
    ma77hew
    Is it possible to avoid making users press Escape key on Pointerlock?
    #68921
    No.
