Camera.controls
Home Forums Puzzles Camera.controls
  • #77080
    thorsten moehle
    Hi There
    After updating i get following Error:
    v3d.Camera.controls replaced by v3d.Camera.controlSettings
    Seems all works fine but is there a location which i have to update in code?
    Thank you!
    #77082
    Hi thorsten,
    Can’t it be that the Puzzles were not re-saved after engine update?
    #77084
    thorsten moehle
    Hi Yuri
    No i just update all our templates and made a new Puzzle and a new Maya scene then i exported.
    (i copy pasted some puzzles from the existing ones)
    I do get the message:
    And in the puzzle i use the set active camera
    #77102
    There was Camera.controls object before Verge3D 4.7. Now it is called Camera.controlSettings to reflect the actual meaning of this structure. We keep both supported for a while, but I’d recommend reviewing your code (puzzles) to find the old construction and make proper adjustments.
    X | FB | LinkedIn
    #77317
    thorsten moehle
    Hi There
    I found the Puzzle causing the issue
    it is “set “allow zoom” “false” to camera “active camera”
    as soon as i use this pzzle i have the message : v3d.Camera.controls replaced by v3d.Camera.controlSettings
    in the console. :scratch:
