Camera angle zoom
Home Forums Puzzles Camera angle zoom
  • #6136
    johngrigni
    Is there a way to change the zoom function to changing the camera angle, like in a camera, as opposed to moving the camera forward, like in a video game?
    #6139
    It is possible in principle I think (check this out for example). Basically you need to change camera FOV instead of position.
    Making it work requires some coding efforts though. Yet right now you can do it in a “jumping” manner at least – create another camera with a different FOV and use the set active camera puzzle.
    #35981
    vklein
    Is there any work on this? I need to change the camera fov (viewing angle NOT position) by mouse-wheel for my project. Setting the camera (fov / zoom) is a must. Atleast give me the posibilitynto use camera fov animation from 3dsmax so I could set animation frame in order to “zoom”.
    #36001
    You can modify the camera FOV via JavaSCript:
    https://www.soft8soft.com/docs/api/en/cameras/PerspectiveCamera.html#fov
    You can do this inside the exec script puzzle and thus integrate with animation puzzles.
    #44485
    beelzebeau
    can you show an example exec script to set the camera focal length?
    Thanks
