Buttons setup
Home Forums General Questions Buttons setup
  • #13970
    NicolaeIonascu
    Hello
    Is it possible to setup buttons for the objects that are behind a transparent object? Or how to make Z-index of transparent object lower than buttons’ objects?
    Thank you.
    #13991
    Can you give some more explanation what you what to achieve, mey be with an example?
    #14589
    Philip Fong
    You have to create a plane with transparent material and place it on top of everything to act as click trigger, png image sometimes don’t work well in mobile so I add this as solution.
