Bug – Verge 3D Error Makes Sacred Geometry!
Home Forums WebGL & WebXR Troubleshooting Bug – Verge 3D Error Makes Sacred Geometry!
  • #50947
    jamdalu
    Attached are captures showing Verge3D apps in Safari on MacBook Pro M1 Max. Unless the goal is a sacred geometry maker, how can anyone recommend Verge3D as a solution with this kind of result?
    #50950
    Hi, this is an issue introduced by Apple developers, not us. Please check out the Verge3D 3.9.1 update which includes workarounds for this weird bug.
    X | FB | LinkedIn
    #50951
    jamdalu
    Confirm that update app to 4 pre 3 also solves the issue. Thanks for the workaround!!
    #50967
    :good:
    X | FB | LinkedIn
