Home › Forums › Graphics / Blender › Brushed Metal
- This topic has 10 replies, 2 voices, and was last updated 4 years, 9 months ago by
Mikhail Luzyanin.
2020-05-19 at 5:05 pm #27775
cristianctin
CustomerHi,
I’m trying to make a brushed metal surface.
I tried a lot of nodes and read all the documentation but unfortunately all I get are just weak dark lines
Please advise me how to obtain a suitable brushed metal with depth so that the brushing pattern can be seen well.
Any advice is very welcome
Thanks?2020-05-19 at 6:18 pm #27778Mikhail Luzyanin
StaffPlease, share this examle with materials so I can correct it a little bit.
2020-05-19 at 9:47 pm #27779cristianctin
CustomerHi,
Please find attached the file.
Thank you Mikhail2020-05-19 at 9:49 pm #27780cristianctin
CustomerThe file was not attached, for some reasons.
2020-05-19 at 9:51 pm #27781cristianctin
CustomerHope now it is OK
2020-05-20 at 4:00 am #27784cristianctin
CustomerThe other map are made with Materialize and are large, so I send them separately.
2020-05-20 at 6:23 am #27795Mikhail Luzyanin
StaffHere’s a proper way to connect a normal map in such material. Here’s a pure blend file without maps, just connect your maps again.
2020-05-20 at 4:21 pm #27827cristianctin
CustomerHi,
It is a good improvement.
However I can not achieve this kind of fine brushed lines ( see attache image ).
In the image it seems that they are engraved ( but they are not, they are using maps ) there is such a vivid combination of black and white and those small ditches has some realistic depth.
I have tweaked the Scale in the Mapping node ( normal, roughness, metallic, maps) but the lines are still very thick.
I have also tried some HDRI but without any success.
Have you any suggestion on how the achieve those kind of fine lines?
Thank you2020-05-21 at 7:03 am #27834Mikhail Luzyanin
StaffYou need to use more suitable normal map with combination of b/w mask and also more blurry matcap for this kind of material. Yo may look at this examples of brushed metall nthey made absolutely from procedural map but may be they will look suitable for you.
2020-05-21 at 7:03 pm #27853cristianctin
CustomerHi,
I tried to follow your advice and I am a step froward, still not exactly what I need ( see attached image ).
I did not exactly understand by “normal map with combination of b/w mask” . I really do not know what do I have to do :)
As you know how my scenes are setup, please tell me if I can use the Jewelry Material Pack for my purposes ?
Basically all I need now, as urgent, is brushed metal and diamond refraction ( the diamond is work in progress, I hope it will be done soon ).
Thank you2020-05-22 at 5:52 am #27862Mikhail Luzyanin
StaffYou can use a simmilar to normal map b/w texture and add over a matcap texture to highlight the brushing little bit. If you can’t make your own normal map to get a good result you can use some textures from our Jewelry library, but you will need to change some parts on the materials to use them. But off cource you can made your own.
