Home › Forums › Programming › Browser becomes unresponsive after running code to screenshot canvas.
- This topic has 4 replies, 2 voices, and was last updated 2 years, 11 months ago by
treefrogmarc.
2023-04-14 at 1:23 pm #62070
treefrogmarc
ParticipantI wrote some code to extract a screenshot from the canvas
function captureImage(filename, scale) { // Get the Verge3D application object. var app = document.v3dApp; // Get the renderer and scene from the application. var renderer = app.renderer; var scene = app.scene; var camera = app.camera; // save the old render target and autoClear state. var oldRenderTarget = renderer.getRenderTarget(); var oldAutoClear = renderer.autoClear; var width = renderer.domElement.width * scale; var height = renderer.domElement.height * scale; // Increase the resolution of the WebGLRenderTarget and the canvas. var renderTargetWidth = width * window.devicePixelRatio; var renderTargetHeight = height * window.devicePixelRatio; var renderTarget = new document.v3d.WebGLRenderTarget( renderTargetWidth, renderTargetHeight, { minFilter: document.v3d.LinearFilter, magFilter: document.v3d.LinearFilter, format: document.v3d.RGBAFormat, stencilBuffer: false, depthBuffer: true } ); // Disable autoClear before rendering to the new target. renderer.autoClear = false; // Render the scene to the WebGLRenderTarget. renderer.setRenderTarget(renderTarget); renderer.render(scene, camera); // Re-enable autoClear and restore the original render target. renderer.autoClear = oldAutoClear; renderer.setRenderTarget(oldRenderTarget); // Increase the resolution of the canvas. var canvas = document.createElement('canvas'); canvas.width = renderTargetWidth; canvas.height = renderTargetHeight; var context = canvas.getContext('2d'); var imageData = context.createImageData(canvas.width, canvas.height); renderer.readRenderTargetPixels(renderTarget, 0, 0, canvas.width, canvas.height, imageData.data); // Flip the image vertically by manipulating the imageData object. var flippedData = new Uint8ClampedArray(imageData.data.length); var stride = canvas.width * 4; // 4 bytes per pixel for (var y = 0; y < canvas.height; y++) { var sourceRow = y * stride; var targetRow = (canvas.height - y - 1) * stride; flippedData.set(imageData.data.subarray(sourceRow, sourceRow + stride), targetRow); } imageData.data.set(flippedData); context.putImageData(imageData, 0, 0); // Convert the rendered image to a data URL. var dataURL = canvas.toDataURL('image/png'); // Use the data URL to create an HTML image element or download the image as a file. // For example, to download the image as a file: var link = document.createElement('a'); link.href = dataURL; link.download = filename + '.png'; link.click(); }It works, and the 3d application continues to work, but only for a few seconds. After that, the program becomes unresponsive. I get no errors, but I assume it’s processing something and taking too much time.
I think it has something to do with changing the render target. Is there anything else I need to do to restore the application after running this code? Are there other ways to capture the image from the canvas?
Thanks,
2023-04-14 at 1:38 pm #62071kdv
ParticipantWhat are trying to do? To get a screenshot from your 3D app?
app.renderer.domElement.toDataURL('image/png')is not a variant?var app = document.v3dApp;
really interesting line )))
2023-04-14 at 1:46 pm #62072treefrogmarc
Participant@kdv yes, I am trying to get a screenshot of the 3D app.
Initially I had that code, but it just produces a blank image.
I also had to flip the bits because the screenshot was coming out upside down
2023-04-14 at 2:07 pm #62073kdv
ParticipantThere is a little easier way. 146% working.
2023-04-14 at 2:44 pm #62076treefrogmarc
ParticipantThat was it. The “enable screenshots” turns on the “preserveDrawingBuffer” which allows to get the pixel data from the canvas.
Perfect, thanks!
