Bounding box problem
Home Forums Bug Reports and Feature Requests Bounding box problem
  • #14878
    loukmaneB
    Hey there is a bug i think between the bounding box computation between 2.11 and 2.12
    If we have an object with morphing in 2.11 if we calculated the bounding box we will get the values of the mesh bounding box in the current state
    But in 2.12.3 the bounding box always equals to the values of the morphing on the max values
    per example if the height morphing of an object is equal to 0.1
    in 2.11 the bounding box will equal to smth like this (1,0.1,1)
    in 2.12 the bounding box will be always equal to (1,1,1) what ever morphing vale is at
    thanks
    #14880
    this is not a bug actually. In 2.12 bounding box is no longer calculated on a model’s original geometry, but rather embraces all possible morph targets assigned to the model.
    Unfortunately, there is no method to get current boundings for morphed objects since they are calculated on GPU level.
    Hope it helps.
    X | FB | LinkedIn
