Boolean objects
Home Forums Graphics / Blender Boolean objects
  • #10056
    rhenriques
    I am trying to use a boolean object, using a subtractive operation, to make parts of the main object disappear when the subtractive one passes through it. In Verge 3D bot geometries appear and no Boolean operation is performed. Is is possible to use boolean objects in Verge 3D?
    #10060
    If you just try to apply current state of the boolean and export it to verge3d then just set Bake Modifiers the Verge3d preferences of the render settings. If you try to keep it dinamicaly changing then it’s will not work, you will need to find another way to do the same: may be shapekeys or, hide/unhide parts, rigging or shader animation.
    #10088
    rhenriques
    Hi Mikhail
    Thank you. That is precisely what I was imagining. The idea was exactly to see things dynamically changing bu moving the subtracting objects with puzzles. I’ll try, in alternative, to cut parts of the model to make them disappear on demand.
    :good:
