Blurry Shadow
Home Forums Graphics / 3ds Max Blurry Shadow
  • #36653
    web
    Hello,
    I’ve got a scene with quite big but very simple geometry with a standard “Target Direction Light” in it. I had to crank up the falloff quite a bit to cover all the geometry.
    Problem which comes with that is that the shadow is quite blurry. What isnt that big of a problem but the shadow is quite noisy. Can I improve the quality of the shadow? Or make it a little bit sharper?
    Shadow is PCF Poisson Disk. Sample Range is 1 and 512px Resolution.
    #36654
    Try to set near and far clipping of the camera as much ckose to the scene geometry and try to increase resolution of shadow map maybe up to 1 or 2k
    #36755
    web
    It did help a tiny bit, but not that much.
    But if there is currently no way to get sharp shadows in such a scene, so be it. :)
    #36756
    If you can share an example max file i can try to setup the shadow.
