Blender shader unwanted interpolation happens between two different colors
Home Forums General Questions Blender shader unwanted interpolation happens between two different colors
  • #56079
    Ilia Bg
    Hi everyone!
    I’ve created a color (RGB) mask, in blender i use “separate RGB” node. Doing it this way results in some interpolation between colors, that later becomes a noticeable line once being exported to verge3d app.
    Is there a way i can avoid this?
    #56089
    Ilia Bg
    Solved!
    Was my bad, just had to use ColorRamp instead of Color/Brightness node
    #56100
    Glad you worked it out :good:
    X | FB | LinkedIn
