hi, im experiencing issues when using constraints, when locked track and child of constraint are used in the same hiearchy there is lag between the child of constraint and when using two locked tracks it doesnt look the same as in blender, are there any limitations compared to blender?
there are two locked track constraints on each cyllinder, one for x axis and one for y axis, try and move the object in both axis to see that it does not pint towards each other in one axis.
if you check the blend file you will se the correct movement,
