- This topic has 6 replies, 2 voices, and was last updated 8 years, 2 months ago by
Pepper KUN.
2018-08-30 at 3:59 am #6824
Pepper KUNCustomerHi,there. I got some issues on bind puzzle. I want to bind a button on an empty object. Here is how my puzzles placing. There is no button element attaching on my pie object. I check the button element on DevTools, there is no left or top css property on my button. Also the red line which should be draw was missing. I don’t know whats going on because console show no error or warning.
Noob on blender and any other things.
2018-08-30 at 4:03 am #6828
Pepper KUNCustomerHere is my html file.
2018-08-30 at 9:12 am #6835
Yuri KovelenovStaffHi,
It was a bug in Puzzles – I’m attaching here a hot fix.
Thanks!
2018-08-31 at 3:08 am #6848
Pepper KUNCustomerThx, It works well now.
By the way, how to rotate an object in Z axis. I try that below but doesn’t work.var red_p = 0.47; var blue_p = 0.15; var i = 180 / Math.PI; var j = 360 / Math.PI; var red_anchor = i*red_p; var blue_anchor = j*red_p + i*blue_p; var white_anchor = i * (red_p + blue_p + 1); var object = app.scene.getObjectByName("pie"); var anchor_red = app.scene.getObjectByName("center_red"); var anchor_blue = app.scene.getObjectByName("center_blue"); var anchor_white = app.scene.getObjectByName("center_white"); var mat = object.material; var index1 = mat.nodeValueMap['red_percent']; var index2 = mat.nodeValueMap['blue_percent']; mat.nodeValue[index1] = red_p; // red part percent mat.nodeValue[index2] = blue_p; // red part percent anchor_red.rotateZ(red_anchor); anchor_blue.rotateZ(blue_anchor); anchor_white.rotateZ(white_anchor);Noob on blender and any other things.
2018-08-31 at 4:06 am #6852
Pepper KUNCustomercolor anchor point(empty object) seems not working properly.
2018-08-31 at 3:24 pm #6859
Glad it worked for you.
Regarding rotation via API, please be advised that the rotateZ method works in engine coordinate system. Z axis in Blender corresponds to Y in Verge3D.
BTW, are you trying to implement billboards? Because you can use the TrackTo constraint with the camera as its target.
2018-09-03 at 3:01 am #6869
Pepper KUNCustomerThx, it’s all done.
Yes, the dots on the end of the lines are quite similar to billboard. I use html element bind to it instead of object Track to camera because I want to change the dot style through CSS file. The other way is not so convenient. Next time I will use object track to camera if I want my billboard can be blocked by other objects.
