- This topic has 9 replies, 2 voices, and was last updated 5 years ago by
Yuri Kovelenov.
2020-03-23 at 11:06 am #24871
web
CustomerI having a hard time to implement a good working “camera switching” in my application.
I need to implement switching between different camera options triggered by the user:
– Camera with only orbit (limited angles) and zoom allowed no panning
– Camera with orbit (still limited angles), zoom and panning.
– “2D” locked camera. Just top viewing with no orbit, just zoom and panning.Because as far as I know its impossible at the moment to change camera settings at runtime. I created different cameras. I can switch between them, but I’m having a hard time to get a smooth transition between the cameras. I get strange jumpings, etc. I just want the change between the cameras become “invisible”.
I would also be okay with creating camera programtically, but I couldnt find any information in the developer api to set options/limits for a perspective camera.
Any ideas?
2020-03-23 at 2:28 pm #24900Yuri Kovelenov
StaffHi,
likely the problem is that when you switch between cameras, the current camera position does not fit in the limits imposed by the previous camera. A possible solution may be that you smoothly reset the camera to some predefined ‘safe’ position before switching it
2020-03-23 at 4:01 pm #24914web
CustomerHmm okay, will have a look.
Can you tell me if it is possible to create a camera directly in javascript with limits/restrictions?
2020-03-24 at 12:35 pm #24945Yuri Kovelenov
Staffyes, I think it should be possible with JavaScript
2020-03-24 at 2:11 pm #24960web
CustomerI already saw that entry, but I couldnt find description in the api to set camera limits.
2020-03-26 at 8:39 am #24987Yuri Kovelenov
StaffSorry, the right page is
https://www.soft8soft.com/docs/api/en/controls/OrbitControls.htmlyou should use app.controls to access these properties and methods.
2020-03-26 at 11:32 am #24993web
CustomerThx, this looks promising.
Do you have to create the camera object pure in javascript or can you get a scene camera and alter the settings?
2020-03-26 at 12:17 pm #24995Yuri Kovelenov
Staff2020-03-26 at 12:44 pm #24998web
CustomerGot it.
app.
didnt work for me in theprepareExternalInterface
function. Got undefined error for “enableZoom” for example. But implementing a function into the “visual_logic.js” viaappInstance.controls.enableZoom = false
did work for me.2020-03-26 at 12:46 pm #25000Yuri Kovelenov
Staffdidnt work for me in the prepareExternalInterface function
try making it inside runCode()
