Best way to load different texture for mobile devices
Home Forums General Questions Best way to load different texture for mobile devices
  • #21780
    mugga
    What would be the best way to load a different texture when using a mobile device?
    At the moment I would think of using the “feature available” puzzle and change the texture for the different materials. But is it possible to iterate through all textures in the scene and use a suffix like “_2k.jp” or “_mobile.jpg”.
    #21782
    you might create a mobile-only gltf and load it instead
    #21784
    Yes, but you will need to do a good trick with naming. You can create a lists of materials and textures in it and then go throu them using loop puzles and change textures in all of them using Replace texture with “flexible texture input” enabled.
