Batch Function Breaks Dependencies
Home Forums Puzzles Batch Function Breaks Dependencies
  • #44230
    jdhutchinson
    Hi!
    SO the batch puzzle is great; but I noticed that it broke down my specific references to objects in, for example, a physics puzzle, to make an object a soft body. After the merge, it no longer has the reference to the object name before it was batched.
    Is this a known limitation, meaning any objects you need specifically to refer to in puzzles needs it’s own material?
    #44250
    Indeed, the batching technique merges individual objects into a new big object for the purpose of decreasing the number of draw calls. Therefore, if you have a dynamic object, you should exclude it from batching.
    #44261
    jdhutchinson
    Thanks Yuri. I will take more care with it now that I know this :good:
