Emission moving/flowing from one direction to another in browser?
Home Forums Graphics / Blender Emission moving/flowing from one direction to another in browser?
  • This topic has 16 replies, 2 voices, and was last updated 1 year ago by c4cc.
Viewing 15 posts - 1 through 15 (of 17 total)
  • #66817
    c4cc
    My file
    • This topic was modified 1 year, 6 months ago by c4cc.
    • This topic was modified 1 year, 5 months ago by c4cc.
    #67591
    c4cc
    It only works in Blender, but in browser, nothing happens. What nodes do I use so that the emission can move/flow in browser as in Blender?
    In Blender:
    original-drawn-by-nanashinayuzu-mochi-53d2788a0d5e217f8b28d256c728bf04
    Shader nodes:
    #67593
    Only Value nodes can be animated to work in Verge3D. Use Combine XYZ connected to the Location input with Value connected to X.
    #67594
    c4cc
    Thanks, this worked. :good:
    #72015
    c4cc
    Sorry for the late reply.
    If I want Emission flowing only once every 5 seconds, which puzzles do I use? There’s no material puzzles for value or combine XYZ puzzles.
    x1
    #72017
    c4cc
    Yes, I can use time puzzles…
    but there are no value puzzles for material.
    #72018
    https://www.soft8soft.com/docs/manual/en/puzzles/Materials.html#materials_get_value
    https://www.soft8soft.com/docs/manual/en/puzzles/Materials.html#materials_set_value
    #72022
    c4cc
    x1
    Here are my puzzles. Sadly, I can’t time the flow of emission.
    x1
    x1
    • This reply was modified 1 year ago by c4cc.
    #72025
    When will you start using your head fo thinking and logic for coding? :scratch:
    Suppose, you have an animation 1 sec long (made in Blender). Suppose, you want this animation to be repeated every 5 sec. You can do it this way:
    #72027
    c4cc
    I’ve tried that, nothing changed.
    x1
    Also, play animation unfortunately does not work for material, I’ve tried
    #72029
    Every 5 seconds (a timer) and After 5 seconds ( a delay) are two big differencies.
    #72030
    c4cc
    x1
    Sadly no change
    #72032
    What’s happening instead? Did you stop you animation before running it by timer? The play animation puzzle won’t work if your animation is already playing.
    #72033
    c4cc
    I can’t time my emission to flow after a certain ttime.
    It’s keyframed under mapping in shader,
    In Blender:
    Shader nodes:
    #72035
    Your initial file. Modified. No puzzles needed. The animation will be repeated every 5 seconds by default.
