Axis from getTransform Puzzle wrong
Home Forums Bug Reports and Feature Requests Axis from getTransform Puzzle wrong
  • #31076
    web
    I found got an issue with animating some params. When I animate an object on the “z-axis”. It works like it should. But when I want to animate the object back and getting the current position via getTransform Puzzle. The “z-axis” is not showing the correct value. When I change the axis for the getTransform puzzle to “x-axis” it is the correct value.
    #31078
    It should work if you’re animating object transformation. Can you share a minimal example of such behavior?
    X | FB | LinkedIn
    #31088
    web
    Never mind, my fault :whistle:
    I forgot that that objectTransform puzzle uses one value per axis. And I was just pasting the value into the wrong axis.
    Think I’ll just use xyz
    #31115
    glad you worked it out! :good:
