Attenuation on lights in 3D max
Home Forums General Questions Attenuation on lights in 3D max
  • #56250
    gf3d
    Hi there,
    i have a question about the attenuation settings in 3D Max.
    I work with 3dmax 2021……
    I work with the Version 4.0.1 of Verge at the moment.
    I noticed that the attenuation of standard light ( Spot and omni )
    doesn´t work anymore…..It did before as far as i noticed.
    These settings are not saved in the gltf file…..
    maybe you guys can check this, because it is a very important
    feature handling light….
    Greets and thanks
    Ger
    #56341
    Hi Ger,
    could you please reproduce this issue in a simplistic scene and share the .max file?
    #56344
    gf3d
    Hi yuri,
    hereby the Max file you asked for…..normally and it was lieke that
    until the latest release of verge you should not see any light on the floor…..now you see the light although the attenuation is set
    in such a way that no light should reach the floor at all.
    The attenuation now only affects the shadow…..
    Greets
    Ger
    #56345
    gf3d
    ok once again it seems the max files is not being uploaded
    one more try
    Greets
    Ger
    #56351
    Indeed there was a bug and we just fixed it! The fix will land in the next preview build of v.4.2. :good:
