Assign material to a multi material object
Home Forums Puzzles Assign material to a multi material object
  • #61840
    seap
    Hi guy,
    Is it possible to assign a material to a specific material slot for an object? I’m Using Blender and my object looks like this:
    Screenshot
    I could simply detach each material into seperated objects and group them but it does not work with the “export to USDZ” puzzle, meaning when I export a group of object I can’t view it in AR with my iPhone.
    So I’m facing the two problems above, solving one would apply to the other. I appreciate any help.
    • This topic was modified 2 years ago by seap.
    #61843
    It’s possible but JS only. Puzzles allow to change only the first material.
    You can. All visible meshes can be exported to USDZ.
    https://v3d.net/9e4
    #61865
    seap
    Thanks your your answer, my Apple AR puzzle looks like this:
    screenshot
    It’s basically a copy of the farmer AR’s puzzle, but if I export a group of objects (Table_008, refer to my Blender screenshot in the original post) I got this error “Object requires a newer version of iOS”. I’ve got the lastest version on my phone and I’ve tested it on a few more and got the same error.
    Here’s the link to my model: link
    #61866
    You should export the Scene object that contains all other objects
    Your puzzles do exporting only once right after the app has been loaded. What’s the point to change materials if they are not exported? If you want to perform exporting on demand you’d better consider this way
    https://www.soft8soft.com/topic/ar-plugin-for-ios/page/2/
    #66254
    Yes. See more info here https://www.soft8soft.com/topic/verge3d-tools-plugin/#post-66231
