Assign material (Multi-sub/Object Material 3ds-Max)
Home Forums Graphics / 3ds Max Assign material (Multi-sub/Object Material 3ds-Max)
  • #7949
    Atomfreak
    Hi
    It seems to be impossible to change a material if my mat is a multi-sub/object.
    The Assign material node does not display the mat in the list.
    #7955
    Yes, it is not possible to change a material on a multi-mat object. As a workaround, split your object so that the parts can be selected independently.
    #24929
    web
    Is it now a days possible to assign multi-mat to objects on runtime? I really would need to find a way to assign materials based on material ids.
    #24986
    this feature would require radical changes in the engine, so for now please use the workaround and split your objects
