- This topic has 9 replies, 3 voices, and was last updated 2 years, 1 month ago by
Ben.
2024-01-29 at 4:22 pm #69999
Ben
CustomerApologies if this has been asked before – can’t quite find the answer I’m looking for!
I’m trying to create a large area of floor tiles, using puzzles to somehow duplicate a source mesh many times. I need the number of rows/columns to be editable by a user, as well as the size of the tiles.
Is there a solution using puzzles? I began using the clone object puzzle but I’m not sure if this would be an efficient way to do it (is there a way to instance meshes instead maybe?)
To make things more complicated I need to be able to flip every other tile so that they form a kind of book-matched pattern (see image attached).
Any help or thoughts would be greatly appreciated
Thanks
2024-01-29 at 4:34 pm #70001kdv
Participantto create a 2D array of clones see the puzzles of this demo
https://cdn.soft8soft.com/demo/blender/clone_object/clone_object.html
A bit of additional logic will allow you to rotate tiles in every even raw.Puzzles and JS coding. Fast and expensive.
2024-01-29 at 5:25 pm #70003
xeonCustomerGiven this is a tile. Perhaps just create controls for a UV map and not worry about the geo?
Tutorials - https://www.xeons3dlab.com2024-01-29 at 5:31 pm #70004kdv
ParticipantUV map controlling won’t allow to combine two neighbouring tiles.
2024-01-29 at 6:45 pm #70009
xeonCustomerStill don’t see the point in trying to flip tiles. A large map with the tiles already flipped as needed in one large texture. Unless you need to allow a user to flip an individual tile having one odd tile in the mix. If you want the user to adjust the orientation of a specific tile, you would just shift the UV the tile width and all other tiles would change with it. But perhaps I don’t fully understand the ask.
KDV sent you an email. Let me know if you are interested.
Tutorials - https://www.xeons3dlab.com2024-01-29 at 7:33 pm #70010kdv
ParticipantXeon, no letters from you today
2024-01-29 at 8:29 pm #70011
xeonCustomergo back a few days….sending again now.
Tutorials - https://www.xeons3dlab.com2024-01-31 at 2:47 pm #70046Ben
CustomerThanks v much for the info. In the end I used the clone puzzle based on the link kdv sent and the tiles are flipped where needed by inverting scale on x/y axes. The repeated uv approach maybe could have worked but I ended up needing to specify a dynamic gap between tiles, so physical polys were easier to manage. Thanks again
2024-01-31 at 2:56 pm #70047kdv
Participantthe tiles are flipped where needed by inverting scale on x/y axes
If those tiles are simmetrical it’s better rotate them by 180 in their local coordinates (change local rotation) instead of flipping scale. Negative scale is not a good approach in any 3D software )))
2024-01-31 at 3:02 pm #70048Ben
CustomerYeah I agree, but unfortunately they’re not symmetrical. I was actually surprised the tops weren’t flipped to backfacing polys when I inverted on one axis. Verge must handle things a little differently (definitely not complaining in this case).
You’re right though I’ll need to keep an eye out for any odd rendering etc going forward..
