Array Modifier Animation
Home Forums Programming Array Modifier Animation
  • #10538
    RenierMyburgh
    Hi there,
    I have an animation in Blender that uses keyframes on the array modifier to work. I have attached a simple example blend of what I mean.
    My question, is there a way to use this animation in Verge3D puzzles? The animation doesn’t seem to be included in the GLTF export like with other object animations.
    Please can you give me some insight :)
    #10540
    Unfortunately, animation of modifier parameters is not supported. You can try to bake it to vertex animation or clone the object in Puzzles instead.
    #10551
    If you want to unhide a part of the mesh you can use shader animation. Like in this example with tube.
