AR with Target
Home Forums General Questions AR with Target
  • #30559
    nectar
    Hi! I just loved the official AR example. But for now what i need is a way to create an AR experience using a static visual target. (which I believe is simpler). Someone knows how can i do that?
    Thanks in advance!
    #30592
    You mean position the model right away? When entering AR mode you’ll get the camera at the origin (0, 0, 0). Simply move the model somewhere further from the origin point.
    X | FB | LinkedIn
    #30638
    nectar
    Hello, thanks for the reply.
    What I want is that the object could follow another real object or an image. The good old image tracking.
    #38777
    parsec
    @nectar
    Hi, did you found if it was possible to do target tracking?
