AR Test Scene Not Working
Home Forums Puzzles AR Test Scene Not Working
  • #40593
    KurtGR
    Hi, so I’ve made a small AR test scene and pretty much copied the AR demo puzzles, just to see if I can do it myself, but it’s not working unfortunately (for both android/ios devices). I don’t know if I’ve missed something or its a bug.
    Android – the hit indicator sprite is stuck around the camera and disappears/reappears when you move, and you can’t see the sphere/cube at all.
    IOS – Won’t even load when clicking the enter AR button, I’ve tried this in the XR Viewer app that is suggested, nothing happens.
    Project zip – https://we.tl/t-9CooO7M4MC
    Any help much appreciated!
    #40811
    psedlacek
    Hello,
    I tested out your project and it looks like a similar issue to what I experienced recently. I suspect the issue is related you your Units setting in Maya. I would try that first, then perhaps investigate the iOS issue separately.
    AR Tracking issue
    Pete
    #40874
    KurtGR
    Thanks for your response – that makes sense for the Android problem, but it doesn’t load at all in IOS?
    #40875
    psedlacek
    If you post a fix with the scale issue fixed and it’s working in Android, I can test on iOS if you’d like.
