AR lighting setup recommendations
Home Forums WebGL & WebXR Troubleshooting AR lighting setup recommendations
  • #52263
    Hi there,
    I am creating an Android and iOS AR experience. For iOS..creating a USDZ switch that is working fine… very limited but it is what it is.
    For Android I was expecting that the lighting I typically use in blender scene would not be needed since the app should use the lighting in the real world room? However when I don’t include lighting I am getting black objects so I am guessing I need some sort of lighting in the scene.
    My question is what sort of light setups are people using? I have tried multiple lights and get errors that prevent the app from running. So far only able to get this to work with a single spot and an HDR environment light.
    What is the best practice?
    #52287
    This feature is supported by Three.js/Verge3D, but not exposed in Puzzles. It just didn’t work well, so we decided to skip it for now.
    HDR environment should be sufficient, even without any other light sources
    #52301
    Thank you. Is this on the road map for future implementation?
