AR in Edge browser
Home Forums General Questions AR in Edge browser
  • #73214
    KUMARA GURU
    The Verge3d AR sample in https://cdn.soft8soft.com/demo/blender/augmented_reality/augmented_reality.html
    works fine in my Android Chrome browser but showing unsupported device message in Edge browser. I tried giving permission to camera and microphone but it’s showing the same issue.
    I tried checking WebAR capability in https://immersive-web.github.io/webxr-samples/. In Chrome browser it’s showing as AR supported device, but in Edge browser it showing as WebAR not supported.
    #73227
    So what is your question? :negative: Which word in “not supported” you didnt understand? If you try Samsung/Xiaomi/Firefox browsers most likely you will get the same result. They don’t work with Google services and AR Core.
    #73253
    Hi @kumara-guru,
    Unfortunately Web AR requires integration with Google’s proprietary “Play Services for AR” which Microsoft Edge currently lacks. :unsure:
    #73326
    KUMARA GURU
    Sorry, if my question is not clear. I asked for a solution to run the AR app in Edge Browser. Thanks.
    #73327
    KUMARA GURU
    Hi @kumara-guru,
    Thanks for the clarification. Is there any workaround for it.
    As we use only Edge browser, can you suggest a way so that we can run Web AR app in Edge browser.
