AR configurator
Home Forums General Questions AR configurator
  • #66663
    krazy4
    I have built a dining configurator in verge 3d + 3ds max and now want to add AR feature as well. But since puzzles doesn’t work on AR screen, what are my options to add “change texture” and “change dining top” button on AR screen.
    Also, is it possible to change table length ?
    #66664
    They work. In Android. In iOS you should make changes before entering AR.
    #66665
    krazy4
    Yeah, sorry I dint mention that. Primary use will be on iOS so it’s important. Is there no way I can make these features for iOS on AR screen:
    1. change textures
    2. change models
    3. change length of the model
    #66666
    No. Not in Verge3D.
    Or you’ll have to use the specific Apple’s software.
    #66667
    krazy4
    The plugin you have created also does the same ? i.e. editing before entering AR mode? This plugin:
    https://kdv77kdv.gumroad.com/l/ar_for_ios?layout=profile
    #66668
    Yes. It just supports morphing as well.
    AR in iOS works as follows:
    Verge3D exports an object (or scene) to a .usdz file (the only step Verge3D is taking part in), Safari downloads this file and sends it to Quick Look which opens this file and shows it in the AR mode. Nothing else.
    #66669
    krazy4
    Thanks a lot for all your responses. Seems like will have to use other platform for this project. Have a great one!
