AR-app tries to load 2 times, then quits
Home Forums General Questions AR-app tries to load 2 times, then quits
  • #61405
    vision
    I have an AR-app that is trying to load 2 times on iOS/safari. Then stops with “an error has occurred’.
    ***solved, it had to point lights in it, when removed, it loaded perfectly.
    • This topic was modified 1 year, 11 months ago by vision.
    • This topic was modified 1 year, 11 months ago by vision. Reason: found the solution myself
    #61415
    glad you worked it out! :good: iOS devices are very sensitive with regard to scene complexity.
    #61420
    A vivid example of how two point lights casting shadows can crash the app in iOS )))
    #61421
    chaomin
    Hi Kdv, do you also provide your paid services?
    #61427
    Hi, adbul! Yes, it’s possible. Depends on what you need.
    Contact me via kdv [at] izh [dot] com.
