Application tab in WordPress plugin not available
Home Forums Bug Reports and Feature Requests Application tab in WordPress plugin not available
  • #60467
    Mariusz
    Hi, recently I updated the WordPress plugin to the newest version (4.2.0) and I noticed that the ‘Application” tab was totally empty. Other tabs were ok, but in the “Application” I couldn’t see the table or “Add new” button. I needed to remove the plugin entirely and install it again to make it work. Of course, I lost my applications that way – luckily I didn’t have many, so I could easily add them again. But it would be a big problem on my client’s websites. Can you, please, check that issue? Thank you!
    #60468
    Hi, is it possible that you got some conflicts with your custom PHP code (or maybe you changed the template files)? Can you provide the server logs to help debug this?
    X | FB | LinkedIn
