App sub-folders
Home Forums Bug Reports and Feature Requests App sub-folders
  • #59754
    NaxosCG
    Hello guys !
    I’m about to start a large 25 Billards table project, where each billard table model will be a separate verge3D application (for many reasons).
    So, is there any chance that the App manager will soon be able to manage some sub-folders, so i can have my app list more tidied / managed with customer folder / app name…
    No need for many levels, just one would be great.
    In the mid-time, i will empty the app manager list moving apps into another folder, but it would help a lot to be able to get folder/subfolder management.
    Best regards.
    #59756
    Hi Claudio,
    Thank you for reminding us about this. We are aware of this problem and it is in our todo list. However there is a disagreement between us on whether it is feasible to implement because it would mean adding further complications to the App Manager. We ourselves got hundred of test projects and feel ok about this :) May be you could implement a naming convention like starting related project names from the same prefix so that thay are properly sorted in the list?
    #59757
    NaxosCG
    I understand, and i am already using a naming convention for this.
    If you can do subfloder , it would be better that lots of lines to look for.
    If coding subfolder makes more difficulties than i can imagine, maybe you could code sort of “working apps list” instead :
    so the app manager would manage several verge3D applications folders, and we could switch from one to another (browse, or better one list)
    My 2 cents.
    #59758
    Thumb upo for this too :good:
