AO map not generated
Home Forums Graphics / 3ds Max AO map not generated
  • #63837
    3dcgi
    Hello
    I enabled AO in 3ds max, using standard values using the verge export plugin
    But when I export no map gets generated
    Any idea what I’m doing wrong
    I noticed that there is a scooter_ao_map inside the scooter example, did verge generate this?
    If not, how would I generate it?
    • This topic was modified 1 year, 11 months ago by 3dcgi.
    Senior CGI Artist @ 3DCGI.Studio #zerophotography
    ➤ Unreal Engine - 3ds max V-Ray
    ➤ Hyper-realistic 3D. Cars, Motorcycles, Products, Archviz Visualizations, 3D & VFX Animations
    #63839
    If you want dynamic AO check out this demo https://cdn.soft8soft.com/demo/max/ambient_occlusion/ambient_occlusion.html
    If you want static AO you need to bake it (in Substance Painter, for example).
    No
    #63855
    No, it was baked manually. Verge3D do not generates AO map. When you enable AO in the Verge3D settings it enables dynamic SSAO on the scene, so no maps will be baked AO generates dynamicaly.
    #63864
    3dcgi
    Thanks for the information. This helps. :good:
