AO map flipped after GLTF export
Home Forums Bug Reports and Feature Requests AO map flipped after GLTF export
  • #57289
    radek
    Hi.
    Verge3D 4.1.1
    Blender 3.3.0
    I have a 3D model where the AO map is in a different UV space.
    This model is correctly loaded into the scene
    But after exporting the scene, the AO map is vertically flipped
    #57297
    that’s because v3d.js creates new textures with flipY = true by default. Why? Maybe it’s a kind of a joke )))
    GLTF and USDZ exporters issue with AO map
    #57324
    Indeed, glTF uses the DirectX format for textures while WebGL follows OpenGL’s. We’ll try to fix this for the next update which we planned for tomorrow.
    #57325
    Changing this.flipY from true to false in the class Texture completely removes the propblem with the occlusion/roughness/metallic texture which is generated by the V3D GLTF exporter.
