Any way to size an object exactly?
Home Forums Puzzles Any way to size an object exactly?
  • #47344
    grimmy
    Hi, I have multiple objects exported from blender. ALthough their transform scale in Blender are all 1,1,1 they are different sizes. I want to be able to set the objects to identical sizes in V3D no matter what scales they are in Blender. Is this possible? I tried both world space and local space but that didn’t seem to make any difference.
    Cheers
    #47380
    To get the real size better to make all objects in base scale with base size that are will be the same. For example if object in 1.5 meter then scale on export 1.5, if object 1 meter then scale on export 1. Unfrotunally, in the engine you can change only a scale of an object.
    #47386
    GLiFTeK
    Possibly make duplicates of each object, then scale their duplicates to all the same size and use the duplicates as guides to scale your original objects in verge?
    Also, if you don’t know, you can ctrl-A and apply transformations in blender if that helps with anything.
    :good:
