Annotations present behind camera
Home Forums Puzzles Annotations present behind camera
  • #6131
    Picklejones
    I’m working on an interactive 360 photo. I’m using annotations to highlight objects and give more information. If I click an annotation, it is still present when I look 180 degrees in the opposite direction (floating in the wrong place). I remember seeing this comment somewhere in the forum but couldn’t locate it with the search. Is there a fix for this behavior?
    #6135
    Can you provide a link or a screeshot of the problem?
    #6137
    Picklejones
    Here’s a gif
    Many thanks Yuri, I love how fast the annotation system is to set up. I may end up using html elements once I fully understand the workflow but for now annotations are the way to go for me. Here the camera is in the center of a sphere with 360 photo texture. The Tissue box has annotation “Tissues” with description “Tissues are fine. They are not a hazard even if swallowed! Delicious :)” If I spin around to look at the opposite side of the room (near a ceiling fan). I still see the description floating there.
    #6138
    Thanks for the report, we’re reproducing this behavior. Will try to this that asap!
    #6142
    Here is the hotfix – just override your v3d.js file in the build directory and update your app with the update button in the App Manager.
    #6144
    Picklejones
    Wow that was fast! Thanks so much.
