Home › Forums › Bug Reports and Feature Requests › Annotations CSS style not changed in 2.8
- This topic has 22 replies, 3 voices, and was last updated 6 years, 5 months ago by
mckachun.
2018-10-10 at 12:11 am #8045
rhenriques
CustomerHi
Just upgraded the v3d.js file into a project (using the update project feature from Verge3d 2.8) and it does something that makes changes in “.v3d.annotation” style impossible. A few labels are maintained but most changed to transparent ones by no apparent reason. The code for them is the same and works fine in V3D 2.7.1. If we try to force change in any annotation style, it’s not assumed.
Cheers2018-10-10 at 7:53 am #8054Yuri Kovelenov
Staff2018-10-10 at 11:50 am #8082rhenriques
CustomerI already had annotations changed this way, using “.v3d-annotation” styles change. I suspect that probably the problem, in this case is really the new fade out features. They shouldn’t be faded in the precise layout that I have but, somehow, they can intersect a little bit the geometry and, for this reason, get faded. It’s a nice feature but, in my model, I need to turn it out. How do I do this via API?
Cheers2018-10-10 at 12:40 pm #8083Yuri Kovelenov
Staff2018-10-10 at 1:22 pm #8089rhenriques
CustomerI’m going to try it. Which is the file?
There’s the visual logic js, the v3d.js and some into the js folder and one with “name of the project js”. Tried them all and no luck. Most labels still are faded. I must be missing something.
Cheers2018-10-10 at 1:27 pm #8090Yuri Kovelenov
Staff2018-10-10 at 5:21 pm #8108rhenriques
CustomerGreat Yuri. Going to try later.
This is a very welcome feature for models of objects or very extruded natural geoforms! It’s not so interesting for landscape models. The ideal was to be able to change this using a puzzle or an option in a puzzle in an annotation by annotation basis. I suppose that it’s difficult to achieve.
Cheers2018-10-10 at 5:43 pm #8111rhenriques
CustomerI’m not achieving the disable of the annotations fading.
Here’s the code change that I did.http://www.dct.uminho.pt/ScreenShot2018-10-10at18.48.png
No luck. It’s possible that the code has some syntax issue?
Cheers2018-10-10 at 5:52 pm #8112rhenriques
CustomerI was testing this new fading feature and I feel that it’s not right. By rotating the model I’ve noticed that it fades annotations even if they are in the front of the model. This is not desirable. Annotations should only fade if they get behind the model, by rotation for instance. In the present form they are fading when they are within the model but in front of it. See the next video with this undesirable effect. In both cases the annotation should always be visible because it’s in the front of the object.
Cheers
2018-10-11 at 8:25 am #8122Yuri Kovelenov
StaffI’m not achieving the disable of the annotations fading.
I think the code I suggested won’t work if annotations are added on some condition later, when an app is already initialized and the runCode function is already triggered.
Obscurity is detected based on objects’ bounding volumes so this feature works best for local distinct objects but not for continued landscapes.
I like your idea about making a setting for turning this feature on and off when needed. I think we will make a minor bug fix release with this setting included.
Thanks for the feedback!
2018-10-11 at 12:16 pm #8134rhenriques
CustomerHi Yuri
Thank you so much for the reply!
Is there any way, for now, to avoid this behavior without make a version regression? I’ve replaced the v3d.js file in an online version to maintain the previous behavior meanwhile. But it’s not the most interesting solution. In one of the apps that I have, this new feature behaves perfectly. I guess that it can be fine tuned to be able to be used with more flat landscape objects such as the one I’ve shown.
That would be awesome! Most users are not “hard coding” guys, such as myself. So it’s always a good idea to make these options available using simple solutions. Probably there are other features that could also have such options. Maybe this could be made via a general “Settings” dialogue.
For now I would like to solve this problem because it’s hard to fine-tune annotations while they are faded :)
Cheers2018-10-11 at 2:37 pm #8147Yuri Kovelenov
StaffMaybe this could be made via a general “Settings” dialogue.
Check it out https://www.soft8soft.com/topic/hotfix-2-8-1/
2018-10-11 at 2:53 pm #8148rhenriques
CustomerHi Yuri
That was quick!!
The solution is perfect this way! I’ve already tested in two apps. In one, without HTML interface, works perfectly. However, in my other project with landscape objects, where I have an HTML interface and the app is into an iframe, the fading disable does not work. I don’t know how I can solve this issue. It’s something linked with changes in the v3D.js file not being updated. I change the fading option but it does not have any consequence. I’ve even erased and recreated again the init conditions puzzle.
Cheers2018-10-11 at 3:07 pm #8149Yuri Kovelenov
Staff2018-10-11 at 3:18 pm #8150rhenriques
CustomerAlready emptied the browser cache. No Luck. Modifications must be made in the v3d.js file. If I backup this one and put the 2.7.1 version one it works great. However, of course, cannot use puzzles because the engine is not the same. When I put the new v3d.js file again in place, despite making fading inactive in the init puzzle, fading remains. Already tested in Safari and Chrome after empty the cache.
PS: Just confirmed that only visual_logic.js and visual_logic.xml are modified by the init puzzle. I guess that the v3d.js, at least, must be patched to better support this feature.
