Home › Forums › General Questions › Annotation issue with Ocean Rendering
- This topic has 10 replies, 3 voices, and was last updated 1 year, 3 months ago by
ps.
2024-01-30 at 2:06 pm #70030
ps
ParticipantHi,
I am using the Verge3D webgl_shaders_ocean example in a V3D App template to render ocean. Also I have some objects floating on the ocean and used annotations on them to identify it.
There are issues with annotations when combined with ocean rendering, as it is not properly getting displayed in their respective positions. Upon adding the ocean, the annotations are not in their fixed positions and keeps moving based on camera movement.I have used the following code to render ocean
Link: https://github.com/Soft8Soft/verge3d-code-examples/blob/master/webgl_shaders_ocean.htmlconst waterGeometry = new v3d.PlaneGeometry(10000, 10000); water = new Water( waterGeometry, { textureWidth: 512, textureHeight: 512, waterNormals: new v3d.TextureLoader().load('textures/waternormals.jpg', function(texture) { texture.wrapS = texture.wrapT = v3d.RepeatWrapping; }), sunDirection: new v3d.Vector3(), sunColor: 0xffffff, waterColor: 0x001e0f, distortionScale: 3.7, fog: scene.fog !== undefined } ); water.rotation.x = - Math.PI / 2; scene.add(water);Also I have noticed that if the line water.rotation.x = – Math.PI / 2; is removed the annotations are properly displayed. But it makes the ocean vertical. Also refer the attached puzzle image for annotations.
Thanks
2024-01-30 at 7:29 pm #70036kdv
Participantinstead of
water.rotation.x = -Math.PI / 2;
try
waterGeometry.rotateX(-Math.PI / 2);
use it as the second line, right afterconst waterGeometryPuzzles and JS coding. Fast and expensive.
2024-01-31 at 8:28 am #70043ps
ParticipantHi @kdv
Thanks for your reply.I tried adding the code in the next line after
const waterGeometrywaterGeometry.rotateX(-Math.PI / 2);But after adding, the reflections in the water appears to be stretched and the annotations are still not in their designated positions and moving along with the camera. Please refer to the attached image.
2024-01-31 at 1:34 pm #70045kdv
ParticipantCould you recreate the issue in a little less complicated app and share this app here?
2024-01-31 at 4:48 pm #70049ps
ParticipantPlease download the verge3d project from the link below
Link: https://drive.google.com/file/d/1kpF6P07HHwm2Dp2EnZH7Ftx0q6s5g2-3/view?usp=sharing
Refer the screenshot attached. Thanks.
2024-01-31 at 6:33 pm #70054kdv
ParticipantConsider using an alternative annotation system. It’s not so difficult given you already have CSS styles.
https://v3d.net/smdhttps://drive.google.com/file/d/1fHAfPulsViVnu4xiPI63V_8IeHJ_3rP4/view?usp=sharing
Something definitly wrong with the Annotation class in
v3d.js. It can take a lot of time to figure out
2024-02-01 at 2:12 pm #70087ps
ParticipantHi @kdv, Thank you very much for your help. I am able to create annotations properly.
How can I add a v3d-annotation-dialog when the user clicks an annotation, to add a description. Also by this approach can we hide (fade) the annotations when it is obscured by some geometry. Please let me know.
Thanks.
2024-02-01 at 5:19 pm #70093kdv
ParticipantHow can I add a v3d-annotation-dialog when the user clicks an annotation
With the help of HTML puzzles (or JS code) and CSS rules. Read a little more about HTML and CSS.
It’s possible with using ray-casting.
2024-02-02 at 8:05 am #70096ps
ParticipantThanks for your suggestions. I will try it.
2025-05-06 at 8:50 am #81766David Duperron
CustomerHi @saravanan!
I would be very curious to have mode details on how you implemented the “ocean” code into your puzzle environment. Could you share your method please?
Thanks in advance!David
2025-05-26 at 4:32 pm #82153ps
ParticipantHi David,
Sorry for the late reply.
For this project, I used Method #2 (Standard) as explained in the manual here:
Using JavaScript – Method 2 (Standard)The ocean rendering code comes from the Verge3D GitHub repository:
Ocean Shader ExampleThanks.
