Annotation hierarchy/z-index
Home Forums General Questions Annotation hierarchy/z-index
  • #46040
    web
    Does anyone how you can alter the hierarchy/z-index of annotations?
    I’ve got the problem that when multiple annotations are present and I move the perspective so that they overlap each other, some of them dont overlap correctly.
    One would suspect that the annotations get a z-index depending on the distance to the camera. Is there anything you can do via javascript?
    Attached a screenshot
    #46080
    yes, you might calculate the distance to the camera each frame, and assign a proper z-index via CSS property.
    #46112
    web
    Okay, managed to implement a fix for my needs, via adding different z-index to the annotations when camera is moving.
    Would it be possible to implement that on your side? I think this would be a plus for many verge3d users.
