Home › Forums › Graphics / 3ds Max › Anisotropic Filtering Setting not visible
- This topic has 17 replies, 5 voices, and was last updated 3 years, 10 months ago by
Mikhail Luzyanin.
2020-11-20 at 6:45 am #35547
toromanovic
ParticipantHi,
when I create a new texture there is no setting for the anisotropic filtering.
The whole “Verge3D Texture Params” is missing.
However, when I open an existing file from the examples and select an texture map the setting is there. When I duplicate this texture the setting stays there. When I create a new texture in this file the setting is missing.Do I need to create the texture in a specific way or do I need to activate something?
2020-11-20 at 9:59 am #35555Yuri Kovelenov
StaffHi,
please check out the Troubleshooting section
https://www.soft8soft.com/docs/manual/en/max/Installation.html#Troubleshooting2020-11-20 at 10:27 am #35557toromanovic
ParticipantHi,
thank you for your reply. Unfortunately it did not work.
The Verge3D Menu bar is there and Auto Assign Verge3D Params is enabled.
I run the script “Add Verge 3D Params” and it worked on one object (my outdoor floor from the scene). When I run the script with the other objects selected it does not work.
The material itself has the Verge3D Material Params (Alpha Mode, Depth Write, …) but the texture map does not show any options for the anisotropic filtering.I am using 3D Max 2019 at the moment. I’m going to install Max 2021 to see if it will fix the problem.
2020-11-20 at 10:53 am #35563Alexander Kovelenov
Staff2020-11-20 at 11:47 am #35564toromanovic
ParticipantHi,
I installed Max 2021 and everything works nice there.
Unfortunately I can not send you the whole file since it is a test design from a client and under NDA.
I exported one part of a mesh for you but when I test-opened the smaller file the anisotropic settings are there but they do not appear in the big file under Max 2019.When I imported the file into 2021 I did a scene convert to Arnold, maybe that fixed the problem becouse he changed every material to physical based.
My initial file is an export from a CAD software and I imported it to Max 2019 through FBX but I’m not sure why this could cause problems?2021-05-04 at 7:06 pm #40721Lungelo Cele
CustomerHi Guys, love your software! I’m busy going through the Verge3D for 3ds Max Basics tutorials on youtube and I am stuck on Part 7 of the tutorials where it says “Improving Graphics Quality”.
The anisotropic filtering setting is not visible for me. I’m using 3ds Max 2021, And so far I tried reinstalling verge3D hoping it would fix the problem but unfortunately still the same problem.
I am using the starter file from night stand and everything I did and learnt perfectly until I got stuck now. Please help :(
2021-05-26 at 10:48 am #41433Lungelo Cele
CustomerCan somebody please help me with the above question??
2021-05-27 at 8:53 am #41514Mikhail Luzyanin
StaffCan you share the max file with textures?
2021-05-30 at 6:23 pm #41597Lungelo Cele
CustomerHi, thanks for the reply. I’ve attached the max file with textures as requested. Again I’m using 3ds Max 2021, following the Verge3D for 3ds Max but stuck on Part 7 of the tutorials where it says “Improving Graphics Quality”. I don’t see the option that they say I should select on my material browser.
2021-05-31 at 6:22 am #41602Mikhail Luzyanin
StaffSeems like files not attached, try to upload files on any file shraing service and leave the link here.
2021-05-31 at 12:35 pm #41626Lungelo Cele
CustomerHi sorry about that, i tried a number of times to attach the file and when clicked the submit button it seemed as if it went through…
Anyway here is the link to the file: https://drive.google.com/file/d/1a7UhVKr3RaRbPOdkeOY9oM_QnAcUsocW/view
2021-05-31 at 2:32 pm #41628Mikhail Luzyanin
StaffI have no access to this file.
2021-05-31 at 2:41 pm #41632Lungelo Cele
CustomerApologies for that, i’ve updated the access to the file. you may view it now.
https://drive.google.com/file/d/1a7UhVKr3RaRbPOdkeOY9oM_QnAcUsocW/view?usp=sharing
2021-05-31 at 2:44 pm #41634Mikhail Luzyanin
StaffCan you also resave max file in 2020 version or lower?
2021-05-31 at 2:53 pm #41635Lungelo Cele
CustomerSure, here is the updated file with the max 2020 file included.
Link: https://drive.google.com/file/d/1ARexeJ6tDcCyjLxXpTNDqPMzQq8m-6wk/view?usp=sharing
