- This topic has 18 replies, 6 voices, and was last updated 4 years, 1 month ago by
Alexander Kovelenov.
2018-06-30 at 6:36 pm #5364
loom
CustomerHi,
just wondering if its possible to add a slider(Playhead) to scrub animation and if its possible to loop a range (in/out) ?
Cheers,
Christian2018-07-02 at 7:45 am #5366Mikhail Luzyanin
Staffjust wondering if its possible to add a slider(Playhead)
It will be possible with new functionality for the next release.
Yes, You need te Set Play animation from and to keyframe, but before you neew to set Repeat of animation Loop mode in the object’s preferences in Blender.
2018-08-09 at 12:20 pm #6274loom
CustomerHi,
i have about 14 induvitual animations on a rigged charakter plus some additional objects running at same time of those animations.the client want to able to scub those animations with a silder (playhead).
What will be the best route to achieve this – maybe with JQuery ? Or is it possible just with puzzles ?
2018-08-09 at 12:31 pm #6276Mikhail Luzyanin
Staffthe client want to able to scub those animations with a silder (playhead).
You can use Drag Over puzzle with a Set animation key-frame puzzle to shift a key-frame by dragging a mouse.
2018-08-09 at 1:51 pm #6291loom
CustomerHi Mikhail,
how can i get negativ values from a slide over? Scrub in one direction is working…https://cdn.soft8soft.com/AROAJSY2GOEHMOFUVPIOE:7ead0c1c56/applications/slider/slider.html
2018-08-09 at 2:00 pm #6298Mikhail Luzyanin
Staffhow can i get negativ values from a slide over?
Why do you need negative values? You can’t insert negative values to animation beause there’s no -1 -2 -3 etc keys.
2018-08-09 at 2:09 pm #6304loom
Customerw wanna have something like this:
i wanna be able to scrub the animation backward and forward. So adding works for forward, but i should be able to substact to go backward.
2018-08-09 at 2:15 pm #6306Mikhail Luzyanin
Staffi wanna be able to scrub the animation backward and forward. So adding works for forward, but i should be able to substact to go backward.
You need to create a trigger at first that you will move using drag< and get position of this trigger that you ill convert to animation frames. So the setup will be Drag On Cube (for example), then Get Cube position and insert it to Keyframe of the Set Keyframe puzzle.
2018-08-09 at 2:47 pm #6318Yuri Kovelenov
StaffSo adding works for forward, but i should be able to substact to go backward.
I guess you need to add some number to the slider position in order to avoid negative key frame values. See the sources of our industrial robot demo where we did that.
2018-08-09 at 3:47 pm #6322loom
CustomerThanks for reply, i try out the Jquery route, i think maybe simpler to set the in/out’s for 16 animations and overlay placement. But thanks a lot for your verry good support.
2019-12-05 at 4:13 pm #21742loom
CustomerHi,
do we have any new possibilities/puzzles for sliders ? I Think this is such a important thing for making playheads or configurators. I do a lot of medical explanation Apps to show how bodymechanics work. My Clients always want the option to scrub thru animations/actions.
I start my next project in january 2020 – any example or even better a puzzle would make me relax for the holidays ;)
Cheers,
Chris2020-01-02 at 3:50 pm #22515procyon
CustomerThis would be an excellent feature. Are there any news on this? :)
https://t.me/pump_upp
2020-01-03 at 3:42 am #22531Yuri Kovelenov
Staff2020-01-03 at 11:59 pm #22542procyon
CustomerThank you for your quick answer.
However, it is not the functionality I’m searching for. What is needed is basically just the “resumeAnimation” with the ability to reverse the resumed animation. I can’t find any other ways of doing this. The “playAnimation” has the “reverse” options, but it always starts the animation from the start.
I have a client asking for this, and any help is greatly appreciated. Thanks.
EDIT: I found this post describing a similar situation, and adding the code below works exactly as I need, however, now the “resumeAnimation” does this for all cases – I need both “resume” and “resumeReverse”.
case 'RESUME': action.paused = false; action.timeScale = -action.timeScale; break;
2020-01-04 at 2:03 am #22545GLiFTeK
CustomerA hack for that would be a loop that increases Or decreases a “playing” variable every frame, and a user click to start/stop it.
Then have your animation be controlled by it via the “set animation frame” puzzle that follows the variable in the loop.
After using math to dial in the proper rates, you’d make the reverse control be times -1.And use what uri mentioned as a playhead scrubber.
You have the position of a handle object (Which uses the when dragged event) put in the “frame” field of the “set animation frame” to (as you would the “playing” variable in the hack
I use that method all the time.Visit the GLIFTEK Verge3D Plugins Store!
