Animation scrubbing?
Home › Forums › Puzzles › Animation scrubbing?
Viewing 15 posts - 1 through 15 (of 21 total)
  • #42301
    possible to scrub back and forth animations by dragging a object around?
    i have a car that is animated to drive a specific path, and would like to pause it and drag it back and forth a specific frame range in the animation.
    #42303
    Yes, it’s possible. THat’s how a wire made in Industrial Robot. It’s animation baked and according to movement of the robot knees it moves.
    #42308
    Very cool! where in the puzzles of the robot should i look for this feature?
    #42311
    it’s in Main tab of Puzzles, in cables_update procedure.
    #42312
    Thanks!
    #42315
    Thanks!
    i see it now, had i only understood it!
    #43620
    vern
    When you say it was ‘animation baked’ how do you do that in 3DS Max so that it works with Verge3D?
    And does it make the animation smoother vs if you used the ‘set animation frame’ puzzle without baking it first?
    I’m using a slider with the ‘set animation frame’ puzzle but it isn’t very smooth because it is moving to each frame instead of smooth interpolation like when you use the ‘play animation’ puzzle.
    Regards
    Vern
    #43623
    vern
    Regards
    Vern
    #43638
    vern
    Don’t know about Max but I usually bake animation in Blender using animation baking tool (may be something 3ds max has try to find on youtube some videos) then export it to max if needed so the animation has each set each keyframe along all animation.
    #43666
    vern
    So baking the animation means it is putting keyframes for each bone on every frame right?
    #43667
    Something like this.
    #43673
    jdhutchinson
    Hi Mikhail,
    Could you, for example, bake into keyframes a cloth + wind simulation? How would you approach this in Blender?
    #43684
    Here’s a simple tutorial how you can do it.
    #43739
    vern
    Thank you Mikhail! I understand.
    So is there anyway to make an animation time-based so that it runs much smoother when using the ‘set frame’ puzzle to scrub back and forth through an animation?
