Animation problem
Home Forums Graphics / 3ds Max Animation problem
  • #38441
    markob
    Hi!
    I’d like to set a composition of sofas in Verge 3d.
    First group (sofa) is only unhided and animation after click on it works fine. Second group have “set position to x…” puzzle and when animation start the animated object changes its position by itself. (see video)
    In 3ds max objects are animated with keyframe and then grouped together.
    They all have the same pivot position.
    How to solve this?
    Also bezier float controller from 3dsmax material doesn’t show in “set value of material”.
    Thanks!
    #38473
    Have you keyframed all x,y,z position of animation for this part or only one? Try to keyframe all x.y.z position even if the have no changes, try also to ungroup and unparent this object too understand where’s the problem.
