Animated UVs Support
Home › Forums › Graphics / Blender › Animated UVs Support
Viewing 1 post (of 1 total)
  • #43513
    jdhutchinson
    Is V3D supposed to support animated UV locations, such as that used for a sprite sheet?
    I have tried looking at the industrial robot example, but I can’t quite understand how it is done. I see a value ‘R’ (probably in place of U) is animated in the shader node, but geometrically it’s a little peculiar the way the 6 planes are actually a single triangulated plane in edit mode.
    Could anybody expand and brek this example down further?
    I managed to make a similar example, using a smoke sprite sheet from babylon.js sample files. Would love to know if people could recommend other sources of good smoke plume sprite sheets.
    It was a really tedious exercise key framing each of 64 UV tile movements though…
