animate UV to move image texture problem
Home Forums General Questions animate UV to move image texture problem
  • #71063
    Claas
    I animated the image texture position
    but I cannot figure out how with puzzles find the animation to trigger it when an event happened.
    adding a material selector does not seem to work and as you can see only object animations are listed
    • This topic was modified 1 year, 1 month ago by Claas.
    #71071
    In materials only Value nodes can be animated. Animations of other nodes will not be exported.
    Only this way will work in Verge3D
    #71091
    Claas
    ah thank you !!!
