Animate param from not smooth
Home Forums Puzzles Animate param from not smooth
  • #25226
    web
    I’m in the middle of optimizing my application for best performance.
    I animate several objects, but I got the issue that there is a small delay right after the beginning of the animation movement. So it starts, then after maybe after 100ms there is a small stop, and then the animation continues. I even reduced the animation to only one group of objects.
    These are the momentary stats of the scene:
    Render Calls: 48
    Triangles Rendered: 191405
    Geometry Buffers: 48
    Textures & Render Buffers: 10
    Someone got an idea to fix this behaviour?
    #25227
    can you attache a scene file with animation?
    #25228
    web
    Sadly not for public. But maybe I can extract parts and build a demo file.
    Can I send a message with a link in private, directly to you?
    #25231
    You can create a simplified demo and attach it here. Unfortunally private support awailable only for Enterprice users or who bought tech support.
