Home › Forums › Graphics / Blender › Alpha with glass, refraction shader
- This topic has 11 replies, 4 voices, and was last updated 7 years, 2 months ago by
Anonymous.
2018-04-09 at 10:06 am #3432
NewFake
CustomerHi,
I saw on the forum that we can add alpha anim to meshes and experimented it successfully, however I tried to use the alpha command within a refraction shader and it didn’t work out; any workaround please?
NewFake :)
2018-04-09 at 10:21 am #3437
Mikhail LuzyaninStaffI saw on the forum that we can add alpha anim to meshes and experimented it successfully, however I tried to use the alpha command within a refraction shader and it didn’t work out; any workaround please?
You need to add Value node to ALpha input of the Output (or Materaisl) node and animate the Value node. Animated materials supported only for node materials.
2018-08-24 at 10:53 pm #6733RMandik
Customerhi
please explain this: (You need to add Value node to ALpha input of the Output (or Materaisl) node and animate the Value node. Animated materials supported only for node materials.)
please can you make some screen of the node tree?
thx2018-08-25 at 8:10 am #6743
Mikhail LuzyaninStaff2019-07-04 at 8:14 am #16066Anonymous
Inactivethis example here looks like that in blender 2.8:
2019-07-04 at 8:17 am #16068
Mikhail LuzyaninStaffthis example here looks like that in blender 2.8:
This example was made year ago. Just mix Transparent shader with any other shader (diffuse for example) and connect value to the value of Mixa Shader. Or connect value to Alpha input of Principled BSDF.
2019-07-04 at 9:08 am #16070Anonymous
Inactiveaha, ok, thanx, thanx :), how do I call that value in puzzle, do you have an example?
2019-07-04 at 9:15 am #16072
Mikhail LuzyaninStaffhow do I call that value in puzzle, do you have an example?
A lot of them you can find in the SDK, but just use Set Value Puzzle. It’s simple.
2019-07-04 at 9:18 am #16073Anonymous
Inactive
2019-07-04 at 12:22 pm #16102Anonymous
InactiveI try to understand something. Why should I animate transparency Chanel. So I’ve got settings in puzzle and wow, something happens there!, but I think I need to put somewhere coordinates for x, y?
The result of my setting now is funny, the water changes only it transparency and does not move. I add a screenshot. So sorry for all my stupid questions.2019-07-04 at 5:44 pm #16147
Mikhail LuzyaninStaffSo I’ve got settings in puzzle and wow, something happens there!, but I think I need to put somewhere coordinates for x, y?
Yes you can separate map node on x,y,z chanells then using add node connvet value to the chanell you want to animate and animate value node, then this will work as animated textures.
2019-07-05 at 11:24 am #16159Anonymous
InactiveOh, yes, now it works :-)) thnx
