Alpha overlay issues
Home Forums Programming Alpha overlay issues
  • #29306
    web
    I got several objects mapped with a transparent png as diffuse map.
    Problem is that when 2 or more objects overlap each other, the overlapping areas are no longer transparent.
    I thought that depthWrite and depthTest should over come that issue, but maybe I’m missing something.
    The material is created during runtime:
    object.material = new v3d.MeshBasicMaterial({
                        map: imageBitmap,
                        transparent: true,
                        depthWrite: true,
                        depthTest: true
    #29312
    GLiFTeK
    Turn off depth write (false) to have material rendered above all others
    (Tool tip shows when hovering over checkmark option in blender if that’s what you’re using)
    #29315
    web
    Will try it, thx :good:
